Hi.
I'm in the process of making my own ROV based on the BlueDotRov system, but with my own hull/frame, as I don't have access to a 3D printer. For now, the planned design is a basic sea wolf. (Think tube with thrusters mounted to it.)
As I'm also thinking of adding an manipulator arm, controlled by another bilge pump, which means I need another Cytron module, which again gives me a spare channel.
With that extra channel, I was thinking of expanding the amount of vertical thrusters with one more, to allow for adjusting horisontal tilt. (2 vertical thrusters in front, one in the back)
Only problem: My knowledge in coding is.. Very much not proficient. I can read some, but coding myself is a challenge. For now. I've looked at the code in Cytron27Aug2019.py and I understand that L/R are left and right forward thrusters and LV/RV is for the vertical thrusters and I understand that I would have to add a section to accommodate for the aft vertical thruster. (Let's just call it AV for Aft Vertical.)
I'm guessing I would have to add this:
DirAV=(Other, available pin(
PwmAV=(Other, available pin)
GPIO.setup(PwmRV,GPIO.OUT)
GPIO.setup(DirRV,GPIO.OUT)
rv=GPIO.PWM(PwmAV,100)
def AV(u):
if(w<=0):
GPIO.output(DirAV,GPIO.HIGH)
av.start(abs(u))
if(w>0):
GPIO.output(DirAV,GPIO.LOW)
av.start(abs(u))The question is: How much else in the code would I have to change to allow for this to be functional?
I tried looking at ControlServer.py and RPiCamServer.py, but that didn't provide much insight to me, due to my limited knowledge of coding.
Any advice? :)
A tour of Rome takes on an entirely new dimension when you include its underground passages and spaces. Unlike the vibrant cityscape above, the underground rome hidden pathways carry an atmosphere of calm discovery, almost like uncovering a secret only a few get to see.
Bonjour @Entrak Entshuldiga ,
J'espère que tu as réussis ton projet, je voudrais aussi ajouter un bras robot à ce ROV.
Merci de me tenir informer .
Bien à toi.
Michel
