Hey al, today started to collect all hardware and started printin. my goal is to use a servo gripper on the rov and use the channel 1 in the app. But wich pin on the raspberry pi communicates with the channel?
thanks in advanc,
Quint
3 comments
Like
3 Comments
Commenting on this post isn't available anymore. Contact the site owner for more info.
Thank you for checking Zac Yap. Thought about that solution, but in the app, you see a channel 1 switch. So there has to be some communication somewhere.
looking through the control code on GitHub I don't see any reference to channel 1 but depending on if you need to tilt the camera or not you could use the pin for the tilt servo for the gripper.
Found it I think. In the Archimedes code under servo it is assigned to gpio14 pin.
