Hi every body,Do you think I can put another moteur (the same than the truster) to the RPI, for make an robot arm ?Did the citron power can support 5 moteurs ?Thanks a lot for your answer !
Salut, moi aussi je ne connais rien à la programmation...
I was hoping someone could figure this out as well. Here is an arm/gripper that uses a bilge pump motor to manipulate it.
https://www.thingiverse.com/thing:3447594
I was hoping someone would modify the app / ROV operating system to support an arm.
I am unfamiliar with programming Python and Java.
